Advanced sheet layer viewport properties
To access additional sheet layer viewport parameters, click Advanced Properties from the Object Info palette of a selected viewport or from the Viewport Style or Edit Viewport Style dialog box. The Advanced Viewport Properties dialog box opens. These settings affect the viewport display only; they do not change the original design layer(s).
Parameter
Description
By Style/Instance
A graphic indicates whether each parameter that can be set by the viewport style is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. A style may have a combination of both settings, to balance the need for consistency and flexibility.
The viewport's style is set on the Create Viewport dialog box or Object Info palette. By Style/Instance settings are established by the style and cannot be changed from the Create Viewport dialog box. To edit the style, see Creating and editing viewport styles; editing the style modifies all viewports in the file that use that style.
Scale Factor
Line Weight Scale
Enter a value larger than 1.0 to increase the viewport line weights, or a value below 1.0 (but larger than 0) to decrease the line weights
Line Type Scale
Enter a value larger than 1.0 to increase the length and spacing of viewport line type segments, or a value below 1.0 (but larger than 0) to decrease the length and spacing of line type segments
Hatch Line Scale
For hatches with page-based units (see Defining and editing hatches), enter a value larger than 1.0 to increase the spacing between viewport hatch lines, or a value below 1.0 (but larger than 0) to decrease the spacing between hatch lines
Text Scale
Enter a value larger than 1.0 to increase the text size in viewports, or a value below 1.0 (but larger than 0) to decrease the text size; only associated viewport text is affected. Graphic objects that are part of the text item, such as a reference marker container or detail callout bubble, are scaled with the text.
Dimensional objects inside plug-in objects, such as dimensions within a grid bubble object, are not scaled. Plug-in objects, such as a North arrow object, are not scaled if they have been placed while editing the viewport in Edit Annotation mode.
Marker Scaling
Select whether markers (such as those found on dimensions, callouts, or other types of annotations) scale automatically according the scale of the viewport, or maintain a fixed scale
Auto scale
Automatically scales markers based on the viewport scale factor; for example, if a marker is on a layer with a scale 1:50 and the sheet layer viewport has a scale of 1:200, the marker will auto scale to 1:4
Custom scale
Sets a scale factor for markers in the viewport
Scale
Set the scale factor for markers; a scale factor below 1.0 decreases the size of the marker relative to its definition at a 1:1 scale, while a factor above 1.0 increases its size
Page Symbol Scaling
These settings affect page-based symbols in the viewport (see Concept: Vectorworks symbols)
Symbol Scale
Sets a scale factor for page-based symbols; a scale factor below 1.0 decreases the size of the symbol relative to its definition at a 1:1 scale, while a factor above 1.0 increases its size
Attribute Scaling
These settings affect the attributes (such as line weight) of page-based symbols in the viewport
Use symbol factor
Uses the Symbol Scale factor to scale the attributes
Use individual factors
Uses the other, individual scale factors in the Advanced Properties dialog box, such as the Line Weight Scale, to scale the page-based symbol attributes
Display with clip cube
If the viewport already has an associated clip cube, this options displays the existing clip cube. If the viewport does not have an associated clip cube, this option creates a clip cube that bounds all visible objects. Access the clip cube to change its dimensions when editing the viewport’s design layer.
Cap Fill/Edge Color
Select the fill and edge colors for the cut lines created by the clip cube crop; these settings override the Vectorworks preference for these attributes to maintain a consistent appearance when the sheet layer is viewed by different users
Cast shadows of removed objects
When rendering, includes shadows cast by objects that are not included in the viewport, for a more realistic effect (especially for interior elevations)
Black and white only
Changes all colors in the viewport to black or white; this is useful for displaying two viewport copies on the same sheet layer, with one in color and the other in black and white. However, if the document preferences display setting is black and white, viewports will also display as black and white even if this option is deselected.
A viewport data visualization (Design Suite product required) overrides this option.
Adjust flipped text
Re-orients rotated and flipped text in the viewport so that it is always readable. The text box stays in the rotated and flipped position relative to the dimension line, but the text itself is re-oriented. (This setting overrides the flipped text preference for the document; see Document preferences: Display tab.)
Re-position dimension text
Re-positions rotated and flipped dimension text in the viewport according to the text position in the dimension standard. The text itself stays in the rotated and flipped orientation, but the text box position relative to the dimension line is changed. (This setting overrides the flipped text preference for the document; see Document preferences: Display tab.)
None fill uses alpha transparency
Displays Shaded render mode and Renderworks viewports with alpha channels so white pixels are not transparent when the fill style is set to None; on Windows, the Use GDI+ imaging Vectorworks preference must be enabled
Drop shadows
Displays any drop shadow attributes added to objects in the original design layer; this setting does not affect drop shadows applied to the viewport object itself
Automatic occlusion culling
Accelerates rendering and uses less memory by removing objects hidden in the current view from the rendering geometry for some projections and Renderworks and Realistic RS render modes. Deselect to see reflections, shadows, and indirect lighting from objects outside the current view.
Preview
Displays the viewport with a preview of the advanced settings
Viewport properties
Creating sheet layer viewports
Viewport styles
